[postgis-devel] [PostGIS] #1188: Implement topology.ST_RemEdgeNewFace
trac at osgeo.org
Mon Sep 19 09:10:24 PDT 2011
Reporter: strk | Owner: strk@…
Type: task | Status: reopened
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Resolution: | Keywords:
Comment(by strk):
Not giving a sign to face 0 might not be a big problem, on a closer look.
The thing is that we can divide the possible outcome of this function into
3 cases:
1) The removed edge is dangling or isolated.
No face is removed and no face is added.
2) The removed edge partecipates in a single ring (universe face on the
other side).
Only one face is removed, no face is added.
3) The removed edge splits two faces.
Both faces are removed, a new face is added.
By using -#, 0, +# we could express all of the cases and still return "the
id of the face taking up the space previously occupied by the removed
edge".
A return > 0 would tell us that a face was created (with the returned id).
A return = 0 would tell us that a face was removed
A return < 0 would tell us that two faces were removed
To know _which_ faces were removed you'd have to look at left_face and
right_face values of the edge _before_ calling the RemEdgeNewFace
function.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1188#comment:8>
