[postgis-devel] Problems compiling ( libtool )
Nathan Clay
clay.nathaniel at gmail.com
Tue Sep 20 15:47:28 PDT 2011
Strk,
I can't seem to find, libtool in either the svn or your git repo at
github.com? Is this an oversight or ....?
Thanks,
Nathaniel H Clay
On Mon, Sep 19, 2011 at 4:58 AM, Sandro Santilli <strk at keybit.net> wrote:
> On Mon, Sep 19, 2011 at 10:55:17AM +0200, Sandro Santilli wrote:
> > On Mon, Sep 19, 2011 at 02:34:09AM -0400, Nathaniel Hunter Clay wrote:
> > > >>/bin/sh ../libtool --mode=compile gcc -g -O2 -fPIC -DPIC -Wall
> > > >>-Wmissing-prototypes -I/usr/include -DPOSTGIS_GEOS_VERSION=32
> > > >>-DPOSTGIS_PROJ_VERSION=47 -c -o stringbuffer.lo stringbuffer.c
> > > >>eval: 1: base_compile+= gcc: not found
> > According to that url, the libtool script in our distribution may
> > be expecting a smarter shell than your /bin/sh.
> Actually, I went looking at what we have in git and that one
> is _not_ using the += construct, so your libtool must ben generated
> on your side (or on the machine which created the distribution that
> you used). If you are building from SVN make sure the "libtool" script
> isn't modified and if it is try reverting it to the upstream version.
> --strk;
> () Free GIS & Flash consultant/developer
> /\ http://strk.keybit.net/services.html
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110920/92b192f0/attachment.html>
