[postgis-devel] Problems compiling ( libtool )
Nathan Clay
clay.nathaniel at gmail.com
Tue Sep 20 20:59:20 PDT 2011
Hi all,
Ubuntu apparently uses dash and redirects all evocations of /bin/sh,
/bin/bash, /bin/rbash etc. to /bin/dash. This was causing the libtool
script to fail. I resolved the issue by running:
sudo dpkg-reconfigure dash and answering no.
Again thanks for all the help! I now have a successful build.
Sincerely,
Nathaniel H Clay
On Tue, Sep 20, 2011 at 10:19 PM, Nathan Clay <clay.nathaniel at gmail.com>wrote:
> Chris,
> I am using Ubuntu 11.10:
> libtool: 2.4
> gcc: 4.6
> GEOS config: /usr/bin/geos-config
> GEOS version: 3.2.2
> GDAL config: /usr/bin/gdal-config
> GDAL version: 1.7.3
> PostgreSQL config: /usr/bin/pg_config
> PostgreSQL version: PostgreSQL 9.1.0
> PROJ4 version: 47
> Libxml2 config: /usr/bin/xml2-config
> Libxml2 version: 2.7.8
> PostGIS debug level: 0
> Thanks,
> Nathaniel H Clay
> On Tue, Sep 20, 2011 at 9:22 PM, Chris Hodgson <chodgson at refractions.net>wrote:
>> I'm pretty sure the actual libtool command gets built by autogen.sh, using
>> "libtoolize" which needs to be on your system, and is usually included in a
>> package called "libtool". What OS are you using? What is the version of
>> libtool? (libtoolize --version)
>> Chris
>> Nathan Clay wrote:
>>> Strk,
>>> I can't seem to find, libtool in either the svn or your git repo at
>>> github.com <http://github.com>? Is this an oversight or ....?
>>> Thanks,
>>> Nathaniel H Clay
>>> On Mon, Sep 19, 2011 at 4:58 AM, Sandro Santilli <strk at keybit.net<mailto:
>>> strk at keybit.net>> wrote:
>>> On Mon, Sep 19, 2011 at 10:55:17AM +0200, Sandro Santilli wrote:
>>> > On Mon, Sep 19, 2011 at 02:34:09AM -0400, Nathaniel Hunter Clay
>>> wrote:
>>> > > >>/bin/sh ../libtool --mode=compile gcc -g -O2 -fPIC -DPIC -Wall
>>> > > >>-Wmissing-prototypes -I/usr/include -DPOSTGIS_GEOS_VERSION=32
>>> > > >>-DPOSTGIS_PROJ_VERSION=47 -c -o stringbuffer.lo stringbuffer.c
>>> > > >>eval: 1: base_compile+= gcc: not found
>>> > According to that url, the libtool script in our distribution may
>>> > be expecting a smarter shell than your /bin/sh.
>>> Actually, I went looking at what we have in git and that one
>>> is _not_ using the += construct, so your libtool must ben generated
>>> on your side (or on the machine which created the distribution that
>>> you used). If you are building from SVN make sure the "libtool" script
>>> isn't modified and if it is try reverting it to the upstream version.
>>> --strk;
>>> () Free GIS & Flash consultant/developer
>>> /\ http://strk.keybit.net/**services.html<http://strk.keybit.net/services.html>
>>> ______________________________**_________________
>>> postgis-devel mailing list
>>> postgis-devel at postgis.**refractions.net<postgis-devel at postgis.refractions.net>
>>> http://postgis.refractions.**net/mailman/listinfo/postgis-**devel<http://postgis.refractions.net/mailman/listinfo/postgis-devel>
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20110920/3e25a8d2/attachment.html>
