[postgis-devel] [PostGIS] #1210: ST_CreateTopoGeom: error in checking phase
trac at osgeo.org
Fri Sep 23 15:18:48 PDT 2011
Reporter: aperi2007 | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
try-ing to compile the last r7888 version of postgis.
I see this error in the ST_CreateTopoGeom test.
regress/st_changeedgegeom. ok
regress/st_createtopogeo. failed (diff expected obtained:
/tmp/pgis_reg_5651/test_16_diff)
regress/st_getfacegeometry. ok
I attach also the logs from check system.
I'm using Postgres 9.1.0 on a RedHat ES6 64 bit.
Regards,
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1210>
