[postgis-devel] KNN and Semantics
    Paul Ramsey
    pramsey at opengeo.org
    Mon Sep 26 13:25:14 PDT 2011
KNNGist walks the index tree to provide ordered results.
Great.
But it's walking the tree, so the results have to be based on boxes.
In the case of points, the box == the point, so the ambiguity collapses.
In the case of everything else, it does not.
So, when someone does
select * from mytable order by geom <-> 'polygon()'::geometry;
what should they get back to provide the minimum surprise? Because
they *will* get back results that differ from
select * from mytable order by distance(geom, 'polygon()'::geometry);
sometimes substantially.
P.
On Mon, Sep 26, 2011 at 1:19 PM, Paragon Corporation <lr at pcorp.us> wrote:
>> So, here's the deal, the KNN search works exclusively against
>> the index. So, it only has boxes available to make decisions
>> (not entirely true, it actually has the full geometry of the
>> query key, but not of the index keys). That means it can
>> return an exact answer for point-on-point queries, but for
>> everything else it'll be a box approximation. So the n-nearest-boxes.
>> There are lots of ways to attack the problem... we can do
>> pure nearest-boxes. We could also convert all the boxes to
>> points, and do nearest-centroids. This might be easiest to
>> explain, potentially. The trouble is, we're going to be
>> returning an approximation for everything except points, so
>> the question is (in my mind) which approximation is easiest
>> to visualize and work with?
> Not sure I understand your question Paul?   I don't see how nearest
> centroids helps much when you are talking
> about largish polygons.  I was thinking this would just make the ST_Expand
> like stuff faster? Oh perhaps I misunderstood that.
> Thanks,
> Regina
> postgis-devel mailing list
> postgis-devel at postgis.refractions.net
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
