[postgis-devel] KNN and Semantics
maplabs at light42.com
Mon Sep 26 14:52:56 PDT 2011
the geometry-to-compare-to is unkown, just a BBOX, but the query
geometry is known
what is to prevent you from using different code to find "the nearest
whatever to a long linestring"
than "the nearest whatever to a small box" ?
With that said, I personally think the commercial use of
"find the location of the nearest things to my point location" is
by far and away the most important, which requires no special code
$0.02
-Brian
On Mon, 26 Sep 2011 14:40:56 -0700, Paul Ramsey
wrote:
Trade-offs abound.
> centroid-vs-centroid has the advantage of ease of understanding
> box-vs-box has the advantage of being over-determined. you could at
> least theoretically do an index-assisted knn pull wrapped as a
> subquery inside a standard st_distance test. however, that goes back
> to magic numbers again (how many items should one pull in the indexed
> query) so...
> There don't seem to be any great soln's here.
> P.
> On Mon, Sep 26, 2011 at 2:35 PM, Paragon Corporation <lr at pcorp.us> wrote:
> > Okay I get the issue now forgot it was for order by stuff. I guess from my
> > perspective bounding box would be better though that's not ideal either.
> > for long linestrings which is what I'm usually dealing with centroid is
> > useless and for small polygons the bounding box is a better approximation
> > than centroid
> > for thumbnail check.
> > It's ST_Distance BTW -- get with the program Paul. Your beloved
> distance is
> > gone. No more. history vamush. :)
> > Thanks,
> > Regina
> >> -----Original Message-----
> >> From: postgis-devel-bounces at postgis.refractions.net
> >> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> >> Behalf Of Paul Ramsey
> >> Sent: Monday, September 26, 2011 4:25 PM
> >> To: PostGIS Development Discussion
> >> Subject: Re: [postgis-devel] KNN and Semantics
> >> KNNGist walks the index tree to provide ordered results.
> >> Great.
> >> But it's walking the tree, so the results have to be based on boxes.
> >> In the case of points, the box == the point, so the ambiguity
> >> collapses.
> >> In the case of everything else, it does not.
> >> So, when someone does
> >> select * from mytable order by geom <-> 'polygon()'::geometry;
> >> what should they get back to provide the minimum surprise?
> >> Because they *will* get back results that differ from
> >> select * from mytable order by distance(geom, 'polygon()'::geometry);
> >> sometimes substantially.
> >> P.
> >> On Mon, Sep 26, 2011 at 1:19 PM, Paragon Corporation
> >> >> So, here's the deal, the KNN search works exclusively against the
> >> >> index. So, it only has boxes available to make decisions (not
> >> >> entirely true, it actually has the full geometry of the query key,
> >> >> but not of the index keys). That means it can return an
> >> exact answer
> >> >> for point-on-point queries, but for everything else it'll be a box
> >> >> approximation. So the n-nearest-boxes.
> >> >> There are lots of ways to attack the problem... we can do pure
> >> >> nearest-boxes. We could also convert all the boxes to
> >> points, and do
> >> >> nearest-centroids. This might be easiest to explain,
> >> potentially. The
> >> >> trouble is, we're going to be returning an approximation for
> >> >> everything except points, so the question is (in my mind) which
> >> >> approximation is easiest to visualize and work with?
> >> > Not sure I understand your question Paul? I don't see how nearest
> >> > centroids helps much when you are talking about largish
> >> polygons. I
> >> > was thinking this would just make the ST_Expand like stuff
> >> faster? Oh
> >> > perhaps I misunderstood that.
> >> > Thanks,
> >> > Regina
> >> > _______________________________________________
> >> > postgis-devel mailing list
> >> > postgis-devel at postgis.refractions.net
> >> > http://postgis.refractions.net/mailman/listinfo/postgis-devel
