[postgis-devel] I want boxes
Paragon Corporation lr at pcorp.us
Tue Sep 27 10:32:05 PDT 2011
Yes lets come up with a symbol we haven't used
> -----Original Message-----
> From: postgis-devel-bounces at postgis.refractions.net
> [mailto:postgis-devel-bounces at postgis.refractions.net] On
> Behalf Of Paul Ramsey
> Sent: Tuesday, September 27, 2011 1:16 PM
> To: postgis-devel at postgis.refractions.net
> Subject: Re: [postgis-devel] I want boxes
> What an exciting opportunity to try out strategy numbers...
> through the magic of PostgreSQL's GiST framework, both
> strategies can be made available using different operators
> (because we love, love, love obscure combinations of symbols).
> P.
> On Tue, Sep 27, 2011 at 10:07 AM, Paragon Corporation
> <lr at pcorp.us> wrote:
> > Paul,
> > If it's not that much harder -- box is better even for
> things that are
> > closish.
> > Take a road -- I can do tests to confirm but box is better
> because I
> > can never use the centroid
> > Centroid tells me the closest is the farthest.  Not
> terribly useful.
> > At least the box will let me know it's useless.
> > With centroid I have no idea if I'm dealing with largish or
> smallish
> > things to consider how credible the answer is.
> >> From: Paul Ramsey [mailto:pramsey at opengeo.org]
> >> Sent: Tuesday, September 27, 2011 1:03 PM
> >> To: Paragon Corporation
> >> Cc: Sandro Santilli; nicklas.aven at jordogskog.no
> >> Subject: Re: I want boxes
> >> Just to point out:
> >> The problem with the centroid is that, for large long
> features, lt's
> >> overselective. So to get the "full potential set" of things you'll
> >> have to winnow down, you need a large first limit.
> >> The problem with the box is that, for large long features, it's
> >> underselective. So you'll get lots of things that aren't actually
> >> very close still showing up al their boxes interact with the
> >> candidate, causing zero-distance returns. The net result is that
> >> you'll still need a large first limit, to ensure that in
> addition to
> >> all the zero-distance false positives you also have the non-zero
> >> results that might actually be the closest.
> >> Which is not to say the box-distance might not be better
> in the end,
> >> just I'm finding in hard to visualize an extreme improvement.
> >> P.
> >> On Tue, Sep 27, 2011 at 9:57 AM, Paragon Corporation <lr at pcorp.us>
> >> wrote:
> >> > If it weren't for the fact it's the centroid of the box, I
> >> would agree
> >> > with you.
> >> > But honestly in many of my cases the centroid of my object
> >> is no where
> >> > near the centroid of the box so pretty useless to base
> >> anything on it.
> >> > Works fine for parcels but not much else I have.
> >> > for the case of polygons etc.  as Nicklas and I think
> others have
> >> > pointed out, the objective is a little different
> >> > not to get the best sort but faster compute the maximum
> >> distance you
> >> > need to stretch out to grab the top 10.
> >> > Though I'm curious how Oracle's NN which is also imperfect works.
> >> > Haven't paid much attention to that.
> >> > Thanks,
> >> > Regina
> >> >> Sent: Tuesday, September 27, 2011 12:52 PM
> >> >> I can almost guarantee you that boxes will be just as
> bad but in a
> >> >> different way... and centroids are always relative to
> the box :) I
> >> >> will think on doing box distance.
> >> >> P.
> >> >> On Tue, Sep 27, 2011 at 9:48 AM, Paragon Corporation
> <lr at pcorp.us>
> >> >> wrote:
> >> >> > As I pointed out to strk -- the centroid appears to be
> >> ceontroid of
> >> >> > the box which is even less useful than I had originally
> >> >> thought.  That
> >> >> > said box distance is way better.
> >> >> > Is it possible to have the distance be box based instead of
> >> >> centroid.
> >> >> > Centroid isn't terrible useful.
> postgis-devel mailing list
> http://postgis.refractions.net/mailman/listinfo/postgis-devel
