[postgis-devel] [PostGIS] #1218: make fails rev7897 / wheezy
trac at osgeo.org
Tue Sep 27 10:38:30 PDT 2011
Reporter: darkblueb | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by darkblueb):
here is the output of make > make.log 2>&1
for s in liblwgeom libpgcommon regress postgis loader utils raster
topology; do \
echo "---- Making all in ${s}"; \
make -C ${s} all || exit 1; \
done;
---- Making all in liblwgeom
make[1]: Entering directory
`/home/shared/srcs_wheezy/postgis_trunk/liblwgeom'
/bin/sh ../libtool --mode=compile gcc -g -O2 -fPIC -DPIC -Wall
-Wmissing-prototypes -I/usr/local/include -DPOSTGIS_GEOS_VERSION=34
-DPOSTGIS_PROJ_VERSION=47 -c -o stringbuffer.lo stringbuffer.c
../libtool: 1: eval: base_compile+= gcc: not found
../libtool: 1: eval: base_compile+= -g: not found
../libtool: 1: eval: base_compile+= -O2: not found
../libtool: 1: eval: base_compile+= -fPIC: not found
../libtool: 1: eval: base_compile+= -DPIC: not found
../libtool: 1: eval: base_compile+= -Wall: not found
../libtool: 1: eval: base_compile+= -Wmissing-prototypes: not found
../libtool: 1: eval: base_compile+= -I/usr/local/include: not found
../libtool: 1: eval: base_compile+= -DPOSTGIS_GEOS_VERSION=34: not found
../libtool: 1: eval: base_compile+= -DPOSTGIS_PROJ_VERSION=47: not found
../libtool: 1: eval: base_compile+= -c: not found
../libtool: 1: eval: CC_quoted+= gcc: not found
../libtool: 1: eval: CC_quoted+= g++: not found
libtool: compile: you must specify a compilation command
libtool: compile: Try `libtool --help --mode=compile' for more
information.
make[1]: *** [stringbuffer.lo] Error 1
make[1]: Leaving directory
make: *** [all] Error 1
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1218#comment:2>
