[postgis-devel] [PostGIS] #1213: [raster] RT_Intersects test fails
PostGIS trac at osgeo.org
Tue Sep 27 18:50:06 PDT 2011
 Reporter:  strk            |       Owner:  pracine
     Type:  defect          |      Status:  new
 Priority:  medium          |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Comment(by robe):
 Mine is failing too now.
 I'm running GDAL trunk r23095.
 This I think is because you didn't take out the old function in the
 regress test since in the diff I get this error.
 ERROR:  function st_intersects(raster, integer, raster, integer) does not
 exist
 HINT:  No function matches the given name and argument types. You might
 need to add explicit type casts.
 so guess different from Sandro's failure.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1213#comment:5>
