[postgis-devel] [PostGIS] #1212: [raster]: st_intersects signature change - documentation out of synch
trac at osgeo.org
Wed Sep 28 10:41:29 PDT 2011
Reporter: robe | Owner: pracine
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis raster | Version: trunk
Keywords: |
Comment(by pracine):
Replying to [comment:13 dustymugs]:
> Replying to [comment:12 pracine]:
> > Replying to [comment:11 dustymugs]:
> > > I like Regina's compromise of turning ST_Intersects(raster, raster,
int, int) into ST_Intersects(raster, raster) with the integers assumed to
be 1 and 1. This is consistent with other raster functions.
> > Yes. This is the default. But what if I want to intersect band 2 of
raster 1 with band 3 of raster 2?
> ST_Intersects(raster1, raster1band2, raster2, raster2band3)
> > At the beginning there was this discussion about forcing users to use
ST_Band() to select a particular band... We choose to add a band parameter
to every function instead. That would be a solution if there is no cost
but what a change for just a couple of variants.
> We don't need ST_Band() and I don't see any mention of ST_Band outside
of this...
> > I guess this is the first function taking two raster band. Right? This
is why we are puzzled so much.
> > On another side: Why is there two versions of _st_intersects(rast
raster, geom geometry, nband integer DEFAULT NULL) in rtpostgis.sql.in.c?
> I kept the old raster converted to geometry functionality due to edge
cases where a geometry-geometry intersects test is true while a raster-
geometry intersects set is false. Check the Working specs for a visual as
I detailed out why I kept it.
> So, if ST_Intersects is called with the first argument being a raster...
> ST_Intersects(raster, geometry)
> the geometry is converted to raster and a raster-raster test ensues
> If ST_Intersects is called with a geometry as the first argument...
> ST_Intersects(geometry, raster)
> the raster is converted to a geometry and a geometry-geometry test
occurs.
> Definitely check the working specs.
Does that mean that ST_Intersects(geometry, raster) is not commutative
anymore? Why touching ST_Intersects(geometry, raster)? Weren't the specs
just for ST_Intersects(raster, raster)?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1212#comment:14>
