[postgis-devel] [PostGIS] #1218: make fails rev7897 / wheezy
trac at osgeo.org
Thu Sep 29 12:54:00 PDT 2011
Reporter: darkblueb | Owner: strk
Type: defect | Status: assigned
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
Comment(by strk):
Everytime you change something you should call 'make distclean' and run
./configure again, otherwise you may hit some caches.
See http://bugs.debian.org/cgi-bin/bugreport.cgi?bug=621743 for the same
bug reported on debian wheezy (for another package being built) In that
bug is reported that setting SHELL in Makefile.in fixed another such case.
I've committed this as r7921 and with r7922 I've fixed "make distclean"
further.
Please try with the updated version, if it still fails after a "make
distclean" and a "./configure" please report:
# env | grep SHELL
# grep -A1 understands config.log
# grep SHELL liblwgeom/Makefile
# grep LIBTOOL liblwgeom/Makefile
If it works, consider gettin back to "dash" shell and trying again,
reportin the same informations when it fails.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1218#comment:9>
