[postgis-devel] [PostGIS] #1224: Provide a topology.ST_ValidateTopology as per ISO specs
PostGIS trac at osgeo.org
Fri Sep 30 04:39:52 PDT 2011
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 The sql/mm specs require an ST_ValidateTopology function.
 We have a ValidateTopology (w/out the ST_ prefix) because we do something
 more than the prescribed checks.
 This ticket is for reviewing the SQL/MM prescriptions and make sure
 there's nothing missing + adding the standard entrypoint.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1224>
