[postgis-devel] [PostGIS] #866: [raster] Change the ST_MapAlgebra nodatavalueexpr text parameter for nodatavaluerepl
PostGIS trac at osgeo.org
Fri Sep 30 11:07:28 PDT 2011
nodatavaluerepl
 Reporter:  pracine         |       Owner:  dzwarg
     Type:  defect          |      Status:  assigned
 Priority:  blocker         |   Milestone:  PostGIS 2.0.0
Component:  postgis raster  |     Version:  trunk
 Keywords:                  |
Changes (by dzwarg):
  * status:  new => assigned
Comment:
 Is this ticket intended to only change the ''name'' of the parameter from
 "nodatavalueexpr" to "nodatavaluerepl"?
 Or does this ticket also imply that the evaluation of the
 "nodatavaluerepl" string will no longer occur, and that any text passed in
 as this parameter gets converted to the raster cell data type and stored
 as "newinitialvalue" in RASTER_mapAlgebra?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/866#comment:4>
