[postgis-devel] [PostGIS] #1745: [postgis-users] make generates incorrect PERL variable value on v1.5.2 from Bill Teluk March 9, 2011
PostGIS trac at osgeo.org
Mon Apr 2 13:25:55 PDT 2012
 Reporter:  ckelloug               |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  medium                 |   Milestone:  PostGIS 1.5.4
Component:  build/upgrade/install  |     Version:  1.5.X
 Keywords:                         |
 There was a bug reported in the mailing list:
 This was a bug where the postgis 1.5.2 build failed on postgres 9.0.4 due
 to $(PERL) being replaced with a non existant version of active perl when
 building  postgis_upgrade_15_minor.sql
 I finally resorted to running strace on make and I have identified the
 problem as bogus paths in pgxs, specfically the file listed below:
 /opt/postgres/9.0/lib/postgresql/pgxs/src/makefiles/../../src/Makefile.global
 This file contains numerous hard coded paths to active state products and
 breaks the 1.5.4 postgis build.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1745>
