[postgis-devel] [PostGIS] #1754: Regress failures against edb windows 64-bit builds
trac at osgeo.org
Wed Apr 4 16:00:03 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: mingw64,windows 64bit |
Comment(by robe):
This is interesting. the 64-bit edb calls their xml lib libxml2-2.dll
which is the same name I compile against. The 32-bit calls theirs
libxml2.dll. No wonder I was so confused.
Think its an incompatibility with the libxml with how its throwing
exceptions. Using the packaged libxml works okay for in out with some
samples that I've done but I think its failing on the tests we have that
throw exceptions.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1754#comment:1>
