[postgis-devel] trunk == 2.0.1
Paul Ramsey pramsey at opengeo.org
Thu Apr 5 17:31:49 PDT 2012
The key here is that folks can just go "upgrade postgis" (whatever the
command it) and end up w/ a non-working system. We want them to go
"get postgis2" and then go through the migration steps. Is that
doable?
P
On Thu, Apr 5, 2012 at 5:30 PM, Angelos Tzotsos <gcpp.kalxas at gmail.com> wrote:
> Hi Chris,
> Thanks for your suggestion.
> Actually I did something different here:
> The published name of the package is the same, so there is a
> postgis-1.5.3.rpm and a postgis-2.0.0.rpm at the same time.
> The name postgis1 is just internal to OBS. Using 'postgis2' would have the
> same result...
> Angelos
> On 04/06/2012 03:12 AM, Chris Hodgson wrote:
>> I think that releasing the postgis 2.0.0 package as "postgis2" is a better
>> approach, as you really don't want people to be able to automatically
>> replace their postgis 1.5 with postgis 2.0.0.
>> Creating postgis1 packages will just force everyone to go through this
>> nasty process... that said, for anyone who has already "upgraded" to 2.0.0
>> using your packages, they will need the postgis1 package to go back and fix
>> things.
>> What a mess!
>> Chris
>> On 12-04-05 04:49 PM, Angelos Tzotsos wrote:
>>> I have now created 'postgis1' as a branch of 1.x
>>> Hope to get this working in a while.
>>> On 04/06/2012 02:38 AM, Paul Ramsey wrote:
>>>> Yeah, maybe it needs to be packaged as 'postgis2' so that people can
>>>> install both versions simultaneously to make upgrading simpler...?
>>>> On Thu, Apr 5, 2012 at 3:31 PM, Angelos Tzotsos<gcpp.kalxas at gmail.com>
>>>>  wrote:
>>>>> Hi Paul,
>>>>> Thanks for the heads up.
>>>>> A possible work around would be to host some 1.5.x binaries on another
>>>>> repository, since OpenBuildService does not archive old versions of the
>>>>> rpms.
>>>>> Since OBS uses version control, I can get the latest 1.5.x postgis
>>>>> version
>>>>> up and running elsewhere. Perhaps we could advertise this solution in
>>>>> postgis documentation somewhere, so that people can see it?
>>>>> I will see if there can be any name convention (like postgis1) for the
>>>>> old
>>>>> version, but this could lead to some other troubles...
>>>>> I will get back with a plan for this.
>>>>> Regards,
>>>>> Angelos
>>>>> On 04/05/2012 11:55 PM, Paul Ramsey wrote:
>>>>>> Angelos, see this
>>>>>> http://gis.stackexchange.com/questions/22945/postgis-2-0-upgrade-problem-with-postgres-data
>>>>>> Is there any way to warn people as they upgrade, because 2.0 is not
>>>>>> backwards compatible with 1.5. They need to dump their database before
>>>>>> they upgrade and run it through postgis_restore.pl while loading it
>>>>>> back into 2.0.
>>>>>> P.
>>>>>> On Tue, Apr 3, 2012 at 1:17 PM, Angelos Tzotsos<gcpp.kalxas at gmail.com>
>>>>>>  wrote:
>>>>>>> OK, no one can hear us :)
>>>>>>> On 04/03/2012 11:15 PM, Paul Ramsey wrote:
>>>>>>>> Yes. Sssssh :)
>>>>>>>> thanks,
>>>>>>>> P
>>>>>>>> On Tue, Apr 3, 2012 at 1:15 PM, Angelos
>>>>>>>>  wrote:
>>>>>>>>> Hi Paul,
>>>>>>>>> I assumed this is the final:
>>>>>>>>> http://postgis.org/download/postgis-2.0.0.tar.gz
>>>>>>>>> Angelos
>>>>>>>>> On 04/03/2012 11:11 PM, Paul Ramsey wrote:
>>>>>>>>>> Are all the versions numbers correct? What did you package off of?
>>>>>>>>>> I
>>>>>>>>>> haven't released the tarball yet...
>>>>>>>>>> P.
>>>>>>>>>> On Tue, Apr 3, 2012 at 1:09 PM, Angelos
>>>>>>>>>>  wrote:
>>>>>>>>>>> On 04/03/2012 10:39 PM, Paul Ramsey wrote:
>>>>>>>>>>>> Devs,
>>>>>>>>>>>> I have tagged 2.0.0. I have not branched a 2.0 yet. I would like
>>>>>>>>>>>> to
>>>>>>>>>>>> hold 2.0 development on trunk until we do a 2.0.1 release. At
>>>>>>>>>>>> that
>>>>>>>>>>>> point we can create a 2.0 branch and bring new features online
>>>>>>>>>>>> in
>>>>>>>>>>>> trunk.
>>>>>>>>>>>> Uploading and preparing text now for release announcement.
>>>>>>>>>>>> P.
>>>>>>>>>>>> _______________________________________________
>>>>>>>>>>>> postgis-devel mailing list
>>>>>>>>>>>> postgis-devel at postgis.refractions.net
>>>>>>>>>>>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
>>>>>>>>>>> Hi all,
>>>>>>>>>>> I have completed packaging of v2.0 for openSUSE.
>>>>>>>>>>> Waiting the announcement to release the rpms :)
>>>>>>>>>>> Regards,
>>>>>>>>>>> Angelos
>>>>>>>>>>> Angelos Tzotsos
>>>>>>>>>>> Remote Sensing Laboratory
>>>>>>>>>>> National Technical University of Athens
>>>>>>>>>>> http://users.ntua.gr/tzotsos
>>>>>>>>> Angelos Tzotsos
>>>>>>> Angelos Tzotsos
>>>>> Angelos Tzotsos
> Angelos Tzotsos
