[postgis-devel] [PostGIS] #1757: Spheroid length functions returning unexpected results.
PostGIS trac at osgeo.org
Fri Apr 6 12:35:56 PDT 2012
 Reporter:  darkpanda  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.1
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
Comment(by darkpanda):
 Ah, okay. That makes sense then, albeit unexpected, as the docs page for
 ST_3DLength_Spheroid doesn't mention this and still refers to the old
 behaviour saying "Will return 0 for anything that is not a MULTILINESTRING
 or LINESTRING", so that should probably be updated.
 I also notice that on the docs page for ST_3DLength_Spheroid, the docs say
 that "in prior versions this used to be called ST_Length_Spheroid3D", but
 I believe the older name for this function was ST_Length3D_Spheroid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1757#comment:2>
