[postgis-devel] [PostGIS] #1762: Provide an unpackaged from 1.5 script
trac at osgeo.org
Sat Apr 7 09:12:10 PDT 2012
Reporter: robe | Owner: pramsey
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
If someone is running 9.1 with 1.5, they can experience a fairly clean
upgrade if their old 1.5 is repackaged as an extension.
Then the upgrade process would be before they backup
1)
CREATE EXTENSION postgis VERSION "1.5.x" FROM unpackaged;
2) run backup
3) create a new database with:
CREATE EXTENSION postgis;
4) Execute legacy_minal.sql
5) restore your backup on new db
By packaging an unpackaged PostGIS 1.5 as an extension -- all the postgis
functions, tables, views from old would be guaranteed not to come back and
mess up a clean postgis 2.0 install and you can still experience a clean
upgrade without perl.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1762>
