[postgis-devel] [PostGIS] #1765: Incorrect ST_Extent example in README_Raster.txt
PostGIS trac at osgeo.org
Tue Apr 10 05:37:12 PDT 2012
 Reporter:  mloskot        |       Owner:  robe
     Type:  defect         |      Status:  new
 Priority:  medium         |   Milestone:  PostGIS Future
Component:  documentation  |     Version:  2.0.x
 Keywords:  extent         |
 Using PostgreSQL 9.1 x86 on Windows 7
 SELECT postgis_raster_lib_build_date(), postgis_raster_lib_version();
 "2012-04-03 23:11:11";"2.0.0 r9605"
 [http://postgis.org/download/windows/ README_Raster.txt] includes the
 following SQL:
 SELECT ST_Extent(rast) FROM rt_test
 which obviously leads to
 ERROR:  function st_extent(raster) does not exist
 LINE 1: SELECT ST_Extent(rast) FROM rt_test
 HINT:  No function matches the given name and argument types. You might
 need to add explicit type casts.
 Apparently, correct command should read
 SELECT ST_Extent(rast::geometry) FROM rt_test
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1765>
