[postgis-devel] [PostGIS] #1759: shp2pgsql st_transform not unique requires casting
trac at osgeo.org
Tue Apr 10 07:44:41 PDT 2012
Reporter: robe | Owner: mcayland
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.0.1
Component: loader/dumper | Version: 2.0.x
Resolution: fixed | Keywords:
Comment(by mcayland):
Okay - I was away at my parents over Easter and their WiFi doesn't always
work that well, so struggling to get internet access. The cast should be
fine - for the first version of the patch, I added the cast inside
ST_Transform() which tripped up one of the regression tests (thanks to
strk for adding this for the new feature!) which is why the explicit cast
now wraps everything.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1759#comment:5>
