[postgis-devel] [PostGIS] #1769: check_auth trigger validation
PostGIS trac at osgeo.org
Wed Apr 11 08:51:34 PDT 2012
 Reporter:  cruizch                                |       Owner:  cruizch
     Type:  patch                                  |      Status:  new
 Priority:  low                                    |   Milestone:  PostGIS 2.0.1
Component:  postgis                                |     Version:  2.0.x
 Keywords:  check_auth, trigger, long transaction  |
 Validate if the trigger check_auth already exists before trying to create
 it in the CheckAuth function for long transaction support. This only
 affects the long_xact.sql.in.c file.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1769>
