[postgis-devel] [PostGIS] #1766: ST_RemEdgeModFace: Allows removing shared edges by universal face and a topogeometry
trac at osgeo.org
Wed Apr 11 12:22:26 PDT 2012
topogeometry
Reporter: jomarlla | Owner: strk
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 2.0.1
Component: topology | Version: trunk
Resolution: fixed | Keywords:
Changes (by strk):
* status: assigned => closed
* resolution: => fixed
Comment:
Fixed in r9627
I meant that the query I was building didn't make sense when universal
face was involved. The query in that case could actually be much simpler
but for now correctness is more important than speed. Second step should
be re-factoring to avoid code duplication (in ST_RemEdgeModFace and
ST_RemEdgeNewFace in this case) and finally speed will be taken in
consideration.
Thanks a lot for this bug report, very welcome.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1766#comment:3>
