[postgis-devel] [PostGIS] #1694: PostGIS 2.0.0 does not build with clang
trac at osgeo.org
Thu Apr 12 08:23:18 PDT 2012
Reporter: vince | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: trunk
Keywords: |
Comment(by vince):
The problem is that PostGIS makefile derives its values for CPP, CFLAGS…
from the PGXS Makefile. There should be a way to override these default
values.
An other bug caused by this dependency: if, for example, I build
PostgreSQL as a universal Apple binary (i386/x86_64) then I am forced to
build also a universal version of PostGIS, even if I don’t want it…
because the flags used to compile PostGreSQL are engraved in PGXS
Makefile…
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1694#comment:19>
