[postgis-devel] [PostGIS] #1468: shp2pgsql-gui table column schema get shifted (was: shp2pgsql-gui append/create/delete/prepare options sitting behind table column)
PostGIS trac at osgeo.org
Fri Apr 13 21:20:01 PDT 2012
 Reporter:  robe           |       Owner:  mcayland
     Type:  defect         |      Status:  new
 Priority:  low            |   Milestone:  PostGIS 2.0.1
Component:  loader/dumper  |     Version:  trunk
 Keywords:                 |
Comment(by robe):
 Mark,
 I don't seem to be able to have issue anymore with
 append/create/delete/prepare.  Waas it once after the table name.  I see
 its at the end but don't recall it being there.
 I do have an issue with some sort of shifting though but it might be the
 issue just moved.  Here are the snapshots.  Happens when I try to change
 name of a table or schema.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1468#comment:6>
