[postgis-devel] [PostGIS] #1784: ST_Transform failure
trac at osgeo.org
Thu Apr 19 08:08:55 PDT 2012
Reporter: georgevl | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.1
Component: postgis | Version: 2.0.x
Keywords: |
Hi all,
Trying to execute the following:
SELECT ST_AsText(ST_Transform(ST_GeomFromText('POINT(2649262.94974021
4579345.79221865)', 3785), 4326))
I get:
NOTICE: PostGIS was unable to transform the point because either no grid
shift files were found, or the point does not lie within the range for
which the grid shift is defined. Refer to the ST_Transform() section of
the PostGIS manual for details on how to configure PostGIS to alter this
behaviour.
ERROR: transform: couldn't project point (2.64926e+006 4.57935e+006 0):
failed to load NAD27-83 correction file (-38)
Based on various comments I found floating around the web, I tried the
environment vars plus copying the zip file etc etc.
The thing that strikes me as most important is that if I restart the PG
Service and try the statement it works, but only once, all subsequent
executions fail!
SELECT postgis_full_version();
"POSTGIS="2.0.0beta3 r9497" GEOS="3.3.3dev-CAPI-1.7.3" PROJ="Rel. 4.7.1,
23 September 2009" GDAL="GDAL 1.9.0, released 2011/12/29" LIBXML="2.7.8"
LIBJSON="UNKNOWN" RASTER"
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1784>
