[postgis-devel] [PostGIS] #1789: ST_CreateTopoGeo, toTopoGeom: ERROR: Invalid edge (no two distinct vertices exist)
PostGIS trac at osgeo.org
Thu Apr 26 08:41:26 PDT 2012
vertices exist)
 Reporter:  strk      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.1
Component:  topology  |     Version:  2.0.x
 Keywords:            |
Comment(by strk):
 note that azimuth is used to order edge ends around a node. There's
 probably a more robust way to do that (as done in GEOS/JTS) but before
 going there it'll be useful to remove some code duplication (the same
 azimuth-based code is in ST_AddEdgeModFace and ST_AddEdgeNewFace, and a
 similar one is in GetNodeEdges)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1789#comment:9>
