[postgis-devel] [PostGIS] #1794: make check under mingw doesn't work
trac at osgeo.org
Mon Apr 30 11:18:00 PDT 2012
Reporter: pramsey | Owner: pramsey
Type: defect | Status: closed
Priority: medium | Milestone: PostGIS 1.5.4
Component: postgis | Version: 1.5.X
Resolution: fixed | Keywords:
Comment(by robe):
Hmm I'll double-check. I assumed you made the same change as you had done
on 2.0 a while ago and I have a hacked script for 2.0 for my mingw 32-bit
to get around it. I'll check next chance I get.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1794#comment:5>
