[postgis-devel] [PostGIS] #1944: Extensions Migration path from 2.1.0 to 2.1.0
trac at osgeo.org
Fri Aug 3 06:04:16 PDT 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: critical | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Keywords: |
Comment(by strk):
or is the version of the script really only found in the file itself ?
Because we could then have the file contain the version including SVN
revision id and always use the same syntax (every run will find a
different version in the script)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1944#comment:3>
