[postgis-devel] [PostGIS] #1946: 'Spatial exception - geometry intersects edge 5' exception at adding 3 polygons
trac at osgeo.org
Fri Aug 3 09:36:13 PDT 2012
polygons
Reporter: wimned | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: topology | Version: trunk
Keywords: |
The code:
CREATE OR REPLACE FUNCTION testerror1()
returns void as
declare geom0 geometry;
declare geom1 geometry;
declare geom2 geometry;
begin
raise notice 'version: %', postgis_full_version();
--perform CreateTopology('wimpy', 4326);
perform CreateTopology('wimpy', 4326, 0.00001);
geom0 = ST_GeometryFromText(
'POLYGON((76.68554 30.74,76.68726 30.74248,
76.69223 30.74157,76.68554 30.74))',4326);
geom1 = ST_GeometryFromText(
'POLYGON((76.68554 30.74,76.67933 30.75,
76.68727 30.74249,76.68727 30.74248,
76.68726 30.74248,76.68554 30.74))',4326);
geom2 = ST_GeometryFromText(
'POLYGON((76.68728 30.74248,76.68727 30.74248,
76.68727 30.74249,76.67933 30.75,
76.69223 30.74157,76.68728 30.74248))',4326);
perform topogeo_AddPolygon('wimpy', geom0);
perform topogeo_AddPolygon('wimpy', geom1);
perform topogeo_AddPolygon('wimpy', geom2);
END
LANGUAGE plpgsql;
Raises the exception mentioned in the title.
Version printed is:
POSTGIS="2.1.0SVN r10156" GEOS="3.3.4-CAPI-1.7.3" PROJ="Rel. 4.7.1, 23
September 2009" LIBXML="2.7.8" TOPOLOGY
I want to use the software to cleanse some external area data.
That is why I use nonzero tolerance.
Code works well, when no tolerance is given.
Geometry of 'edge number 5' is
LINESTRING(76.67933 30.75,76.68727 30.74249,
76.68727 30.74248,76.68726 30.74248)
Geometry of curve to be added:
LINESTRING(76.6872793512476 30.7424764568138,
76.68727 30.74249,76.67933 30.75)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1946>
