[postgis-devel] [PostGIS] #1952: pg_restore is just an .in and not pre-built in tar ball
trac at osgeo.org
Thu Aug 16 09:08:33 PDT 2012
Reporter: robe | Owner: strk
Type: defect | Status: closed
Priority: blocker | Milestone: PostGIS 2.1.0
Component: build/upgrade/install | Version: trunk
Resolution: invalid | Keywords:
Changes (by robe):
* status: new => closed
* resolution: => invalid
Comment:
Ah okay. I'll dismiss this then. I guess anyone downloading the tar ball
is going to compile and it will be built. I already changed the windows
build bot to distribute the generated ones before. Before I was just doing
an svn export.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1952#comment:2>
