[postgis-devel] [PostGIS] #1954: Test failures in 1.5 branch (includes crashes!)
PostGIS trac at osgeo.org
Fri Aug 17 03:02:45 PDT 2012
 Reporter:  strk      |       Owner:  pramsey
     Type:  defect    |      Status:  new
 Priority:  critical  |   Milestone:  PostGIS 1.5.5
Component:  postgis   |     Version:  1.5.X
 Keywords:            |
 As of r10085, after manually wiping out all .o .a and .so files, this is
 the result of {{{ make clean && ./autogen.sh && ./configure && make &&
 make check }}}:
 *** regress_ogc_prep_expected   Tue May 22 11:16:14 2012
 --- /tmp/pgis_reg_18825/test_45_out     Fri Aug 17 12:00:10 2012
 *** 4,21 ****
   intersects102|f
   intersects103|t
   intersects104|f
 ! contains099|t
 ! contains100|t
 ! contains101|f
 ! contains102|f
 ! contains103|f
 ! contains104|f
 ! covers099|t
 ! covers100|t
 ! covers101|t
 ! covers102|f
 ! covers103|t
 ! covers104|f
   containsproperly099|t
   containsproperly100|t
   containsproperly101|f
 --- 4,11 ----
   intersects102|f
   intersects103|t
   intersects104|f
 ! ERROR:  lwgeom_size called with unknown-typed serialized geometry
 *** 34,42 ****
   intersects108|f
   intersects108|f
   intersects108|f
 ! contains105|t
 ! contains105|t
 ! contains105|t
   contains106|f
   contains106|f
   contains106|f
 --- 24,30 ----
   intersects108|f
   intersects108|f
   intersects108|f
   contains106|f
   contains106|f
   contains106|f
 *** 58,66 ****
   containsproperly108|f
 ! covers105|t
 ! covers105|t
 ! covers105|t
   covers106|f
   covers106|f
   covers106|f
 --- 46,52 ----
   covers106|f
   covers106|f
   covers106|f
 Etc. etc.
 There are actually more, including this:
 *** tickets_expected    Fri Aug 17 11:48:27 2012
 --- /tmp/pgis_reg_18825/test_50_out     Fri Aug 17 12:00:10 2012
 *** 49,98 ****
   #259|
   #260|1667701
   #261|0
 ! #262|POINT(-119.5434 34.9438)|t|t|t
 --- 49,52 ----
   #259|
   #260|1667701
   #261|0
 ! connection to server was lost
 Sounds pretty drastic
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1954>
