[postgis-devel] [PostGIS] #1955: Exception when 2 edges passed to ST_ModEdgeHeal() that are attached to the same 2 nodes
PostGIS trac at osgeo.org
Fri Aug 17 10:20:03 PDT 2012
same 2 nodes
  Reporter:  wimned    |       Owner:  strk
      Type:  defect    |      Status:  closed
  Priority:  medium    |   Milestone:  PostGIS 2.0.2
 Component:  topology  |     Version:  2.0.x
Resolution:  fixed     |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * version:  trunk => 2.0.x
  * resolution:  => fixed
  * milestone:  PostGIS 2.1.0 => PostGIS 2.0.2
Comment:
 Fixed by r10188 in 2.0 branch and r10189 in trunk (although I can't really
 test trunk due to #1956)
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1955#comment:8>
