[postgis-devel] [PostGIS] #1953: ST_MakeValid don't work
PostGIS trac at osgeo.org
Fri Aug 17 10:24:45 PDT 2012
  Reporter:  aperi2007  |       Owner:  strk
      Type:  defect     |      Status:  closed
  Priority:  medium     |   Milestone:  PostGIS 2.1.0
 Component:  postgis    |     Version:  trunk
Resolution:  invalid    |    Keywords:
Changes (by strk):
  * status:  assigned => closed
  * resolution:  => invalid
Comment:
 So I tested and it's the same back to 1.4 too.
 So this ticket is invalid. If you want an _enhancement_  (if you consider
 it such) you can file another.
 I think we already discussed this with the rest of the crew and people
 (especially Mark) thought we'd better not easily let invalid geometries
 in, when the check is easy to perform.
 The loader would be using WKB, which we let in as invalid.
 Indeed most testcases for MakeValid use WKB input. Not very readable, but
 works as a workaround.
 I've to say I'd be in favor of allowing invalid WKT input. But could also
 become a run time configuration setting (GUC).
 Anyway, closing this as invalid.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1953#comment:3>
