[postgis-devel] [PostGIS] #1958: ST_Intersects(geography) returns incorrect result when called multiple times
PostGIS trac at osgeo.org
Wed Aug 22 10:12:48 PDT 2012
times
  Reporter:  realityexists  |       Owner:  pramsey
      Type:  defect         |      Status:  closed
  Priority:  medium         |   Milestone:  PostGIS 2.1.0
 Component:  postgis        |     Version:  trunk
Resolution:  fixed          |    Keywords:
Comment(by robe):
 Okay will add one later.  I like the double-testing just because I've run
 into issues where CUnit passes and the PostgreSQL one fails and also I
 can't really test the VC++ PostgreSQL compiled ones reliably under CUnit
 since Cunit is no guarantee of how it will actually behave under
 PostgreSQL.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1958#comment:10>
