[postgis-devel] [PostGIS] #1963: Windows buildbot regress failure on pgsql regress test
trac at osgeo.org
Thu Aug 23 00:02:27 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: new
Priority: blocker | Milestone: PostGIS 2.1.0
Component: postgis | Version: trunk
Keywords: |
Just noticed my windows buildbot has been failing on regress test for the
past day or so
PostGIS is now configured for i686-w64-mingw32
-------------- Compiler Info -------------
C compiler: i686-w64-mingw32-gcc -g -O2
C++ compiler: i686-w64-mingw32-g++ -g -O2
SQL preprocessor: /mingw/bin/cpp -traditional-cpp -P
-------------- Dependencies --------------
GEOS config: /c/jenkins/geos/rel-3.4.0devw32/bin/geos-config
GEOS version: 3.4.0dev
GDAL config: /c/jenkins/gdal/rel-1.9.1w32/bin/gdal-config
GDAL version: 1.9.1
PostgreSQL config:
/c/jenkins/postgresql/rel/pg9.2beta2w32/bin/pg_config
PostgreSQL version: PostgreSQL 9.2beta2
PROJ4 version: 48
Libxml2 config: /c/ming32/projects/libxml/rel-
libxml2-2.7.8w32/bin/xml2-config
Libxml2 version: 2.7.8
JSON-C support: yes
PostGIS debug level: 0
Perl: /bin/perl
--------------- Extensions ---------------
PostGIS Raster: enabled
PostGIS Topology: enabled
-------- Documentation Generation --------
xsltproc: /c/ming32/projects/xsltproc/xsltproc
xsl style sheets: /c/ming32/projects/docbook/docbook-xsl-1.76.1
dblatex:
convert: /c/Windows/system32/convert
mathml2.dtd: http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
CUnit - A unit testing framework for C - Version 2.1-2
http://cunit.sourceforge.net/
PostgreSQL 9.2beta2 on i686-w64-mingw32, compiled by
i686-w64-mingw32-gcc.exe (GCC) 4.5.4 20111030 (prerelease) [svn/rev.180676
- mingw-w64/oz], 32-bit
Postgis 2.1.0SVN
- r10195
- 2012-08-22 22:06:20
GEOS: 3.4.0dev-CAPI-1.8.0 r0
PROJ: Rel. 4.8.0, 6 March 2012
Running tests
loader/Point .............. ok
loader/PointM .............. ok
loader/PointZ .............. ok
loader/MultiPoint .............. ok
loader/MultiPointM .............. ok
loader/MultiPointZ .............. ok
loader/Arc .............. ok
loader/ArcM .............. ok
loader/ArcZ .............. ok
loader/Polygon .............. ok
loader/PolygonM .............. ok
loader/PolygonZ .............. ok
loader/TSTPolygon ......... ok
loader/TSIPolygon ......... ok
loader/TSTIPolygon ......... ok
loader/PointWithSchema ..... ok
loader/NoTransPoint ......... ok
loader/NotReallyMultiPoint ......... ok
loader/MultiToSinglePoint ......... ok
loader/ReprojectPts ........ ok
loader/ReprojectPtsGeog ........ ok
loader/Latin1 .... ok
binary .. ok
regress .. failed (diff expected obtained: /tmp/pgis_reg/test_24_diff)
regress_index .. ok
regress_index_nulls .. ok
lwgeom_regress .. ok
regress_lrs .. ok
removepoint .. ok
setpoint .. ok
simplify .. ok
snaptogrid .. ok
summary .. ok
affine .. ok
empty .. ok
measures .. ok
legacy .. ok
long_xact .. ok
ctors .. ok
sql-mm-serialize .. ok
sql-mm-circularstring .. ok
sql-mm-compoundcurve .. ok
sql-mm-curvepoly .. ok
sql-mm-general .. ok
sql-mm-multicurve .. ok
sql-mm-multisurface .. ok
polyhedralsurface .. ok
polygonize .. ok
postgis_type_name .. ok
geography .. ok
out_geometry .. ok
out_geography .. ok
in_gml .. ok
in_kml .. ok
iscollection .. ok
regress_ogc .. ok
regress_ogc_cover .. ok
regress_ogc_prep .. ok
regress_bdpoly .. ok
regress_proj .. ok
regress_management .. ok
dump .. ok
dumppoints .. ok
wmsservers .. ok
wkt .. ok
wkb .. ok
tickets .. ok
typmod .. ok
remove_repeated_points .. ok
split .. ok
relate .. ok
bestsrid .. ok
concave_hull .. ok
hausdorff .. ok
regress_buffer_params .. ok
offsetcurve .. ok
relatematch .. ok
isvaliddetail .. ok
sharedpaths .. ok
snap .. ok
node .. ok
unaryunion .. ok
clean .. ok
relate_bnr .. ok
delaunaytriangles .. ok
in_geojson .. ok
uninstall .. ok (4061
Run tests: 87
Failed: 1
above is from 9.2, but I think 9.1 and 9.0 are failing as well. I'll look
at the diff in a bit.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1963>
