[postgis-devel] [PostGIS] #1345: ST_StartPoint, ST_EndPoint regress failure
trac at osgeo.org
Sat Aug 25 09:15:34 PDT 2012
Reporter: robe | Owner: pramsey
Type: defect | Status: closed
Priority: critical | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Resolution: fixed | Keywords:
Comment(by pramsey):
Judging by the differences in code from 1.5 to 2.0 the change was a side
effect of the serialization change, since the original code worked against
"inspected geometries", that is, direct access to the serialization. The
original code was also pretty clearly deliberately unwrapping the first
instance of the targeted type within any multi* geometries it was handed.
So if it was handed a geometry collection or multilinestring, it would
unwrap and then use the *first* instance it found to answer the call.
Whether the benefit of auto-unwrapping of things like single-entry
linestrings outweighs the surprise of the end point of a double entry
multlinestring being the end of the first entry, I leave as an exercise to
the user.
I noticed the problem working on my tutorial, which includes some calls to
NumInteriorRings that previously transparently unwrapped a multipolygon to
the first entry.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1345#comment:9>
