[postgis-devel] [PostGIS] #1967: Check failed on in-gml & in-kml in pg 2.0.1
PostGIS trac at osgeo.org
Sun Aug 26 09:15:00 PDT 2012
 Reporter:  aperi2007  |       Owner:  pramsey
     Type:  defect     |      Status:  new
 Priority:  medium     |   Milestone:  PostGIS 2.0.2
Component:  postgis    |     Version:  2.0.x
 Keywords:             |
 Hi,[[BR]]
 try-ing to compile the postgis 2.0.1 I see these two errors in make check
 phase:[[BR]]
  in_gml .. failed (diff expected obtained:
 /tmp/pgis_reg/test_52_diff)[[BR]]
  in_kml .. failed (diff expected obtained:
 /tmp/pgis_reg/test_53_diff)[[BR]]
 I attach the logs about these errors.[[BR]]
 Now I'm go to test the postgis-svn version.[[BR]]
 My environment is:[[BR]]
 Red Hat Enterprise 6.3.[[BR]]
 This is the first time I try the postgis 2.0.1 . Before I use the Postgis
 2.0.0. So I don't have any reference. But just few day ago I update the
 libxml to the 2.8.0 version. I guess this could be a good candidate for
 this problem ?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1967>
