[postgis-devel] [PostGIS] #1970: copytopology regress on 9.2rc1 windows 32
PostGIS trac at osgeo.org
Tue Aug 28 11:23:57 PDT 2012
 Reporter:  robe      |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.1.0
Component:  topology  |     Version:  trunk
 Keywords:            |
 could be something with my config though rest seems to work fine.  I'm
 getting a regress on copy topology on my 9.2rc1 x32 windows bot.
 25.OBT: layer_id_seq|1|1|1|9223372036854775807|1|1|1|f|f
 25.EXP: layer_id_seq|1|1|1|9223372036854775807|1|1|0|f|f
 PostgreSQL 9.2rc1 on i686-w64-mingw32, compiled by
 i686-w64-mingw32-gcc.exe (GCC) 4.5.4 20111030 (prerelease) [svn/rev.180676
 - mingw-w64/oz], 32-bit
   Postgis 2.1.0SVN
  - r10206
  - 2012-08-28 17:51:39
   GEOS: 3.4.0dev-CAPI-1.8.0 r0
   PROJ: Rel. 4.8.0, 6 March 2012
 Running tests
  regress/legacy_validate .. ok
  regress/legacy_predicate .. ok
  regress/legacy_invalid .. ok
  regress/sqlmm .. ok
  regress/legacy_query .. ok
  regress/addnode .. ok
  regress/addedge .. ok
  regress/addface .. ok
  regress/addface2.5d .. ok
  regress/addtopogeometrycolumn .. ok
  regress/polygonize .. ok
  regress/st_addisoedge .. ok
  regress/st_addisonode .. ok
  regress/st_addedgemodface .. ok
  regress/st_addedgenewfaces .. ok
  regress/st_changeedgegeom .. ok
  regress/st_createtopogeo .. ok
  regress/st_getfacegeometry .. ok
  regress/st_getfaceedges .. ok
  regress/st_modedgeheal .. ok
  regress/st_modedgesplit .. ok
  regress/st_newedgeheal .. ok
  regress/st_newedgessplit .. ok
  regress/st_remedgenewface .. ok
  regress/st_remedgemodface .. ok
  regress/topoelement .. ok
  regress/topoelementarray_agg .. ok
  regress/topogeo_addlinestring .. ok
  regress/topogeo_addpoint .. ok
  regress/topogeo_addpolygon .. ok
  regress/topogeometry_type .. ok
  regress/topo2.5d .. ok
  regress/totopogeom .. ok
  regress/droptopology .. ok
  regress/copytopology .. failed (diff expected obtained:
 /tmp/pgis_reg/test_35_diff)
  regress/createtopogeom .. ok
  regress/createtopology .. ok
  regress/gml .. ok
  regress/getnodebypoint .. ok
  regress/getedgebypoint .. ok
  regress/getfacebypoint .. ok
  regress/getringedges .. ok
  regress/gettopogeomelements .. ok
  regress/layertrigger .. ok
  regress/validatetopology .. ok
  uninstall .. ok (4061
 Run tests: 46
 Failed: 1
 confgure details:
  PostGIS is now configured for i686-w64-mingw32
  -------------- Compiler Info -------------
   C compiler:           i686-w64-mingw32-gcc -g -O2
   C++ compiler:         i686-w64-mingw32-g++ -g -O2
   SQL preprocessor:     /mingw/bin/cpp -traditional-cpp -P
  -------------- Dependencies --------------
   GEOS config:          /c/jenkins/geos/rel-3.4.0devw32/bin/geos-config
   GEOS version:         3.4.0dev
   GDAL config:          /c/jenkins/gdal/rel-1.9.1w32/bin/gdal-config
   GDAL version:         1.9.1
   PostgreSQL config:
 /c/jenkins/postgresql/rel/pg9.2rc1w32/bin/pg_config
   PostgreSQL version:   PostgreSQL 9.2rc1
   PROJ4 version:        48
   Libxml2 config:       /c/ming32/projects/libxml/rel-
 libxml2-2.7.8w32/bin/xml2-config
   Libxml2 version:      2.7.8
   JSON-C support:       yes
   PostGIS debug level:  0
   Perl:                 /bin/perl
  --------------- Extensions ---------------
   PostGIS Raster:       enabled
   PostGIS Topology:     enabled
  -------- Documentation Generation --------
   xsltproc:             /c/ming32/projects/xsltproc/xsltproc
   xsl style sheets:     /c/ming32/projects/docbook/docbook-xsl-1.76.1
   dblatex:
   convert:              /c/Windows/system32/convert
   mathml2.dtd:          http://www.w3.org/Math/DTD/mathml2/mathml2.dtd
 I thought someone had a similar issue on user group, but can't find that
 note.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1970>
