[postgis-devel] [PostGIS] #1966: Hudson appears to be down as far as I can tell
trac at osgeo.org
Fri Aug 31 20:19:17 PDT 2012
Reporter: robe | Owner: robe
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.1.0
Component: management | Version: trunk
Keywords: |
Comment(by robe):
Bborie,
I was thinking Debian since that is common but I don't think they even
have a 2.0 out for it. I could be wrong.
On another note while we are deciding on a new Linux bot, I added a job on
Winnie to build the PostGIS 2.10 tar ball (that's the new name I'm going
to call it for Winnie the Pooh :) )
Can you all test to see if it's up to Linux worthiness.
I put a tar ball up generated by my winbot. Can you test it for Linux
worthiness?
I figure while we are building the new linbot, I'd feel more comfortable
if my current can serve as a backup.
http://www.postgis.org/download/postgis-2.1.0SVN_r10215.tar.gz
One thing I had to do in addition to the standard make_dist.sh stuff is to
pass the folder thru dos2unix since when I do the svn export , it exports
as windows native format which I think is offensive to Linux machines.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1966#comment:4>
