[postgis-devel] Build failed in Jenkins: GEOS_Branch_3.3_mingw64_win64 #9
Sandro Santilli
strk at keybit.net
Wed Dec 5 07:53:39 PST 2012
Regina, what version of automake is installed on winnie ?
Could you try this patch there:
diff --git a/configure.in b/configure.in
index 1369311..66803ad 100644
--- a/configure.in
+++ b/configure.in
@@ -37,8 +37,7 @@ CAPI_VERSION="$CAPI_VERSION_MAJOR.$CAPI_VERSION_MINOR.$CAPI_VERSION_PATCH"
AM_INIT_AUTOMAKE([geos], [$VERSION], [no-define])
AM_MAINTAINER_MODE
-AM_CONFIG_HEADER([include/config.h])
-AM_CONFIG_HEADER([include/geos/platform.h])
+AC_CONFIG_HEADERS([include/config.h include/geos/platform.h])
AC_PROG_CC
dnl use libtool ----------------------------------------------------------
--strk;
On Wed, Dec 05, 2012 at 08:51:02AM +0100, Sandro Santilli wrote:
> On Wed, Dec 05, 2012 at 12:35:31AM -0500, winnie at postgis.net wrote:
> > See <http://winnie.postgis.net:1500/job/GEOS_Branch_3.3_mingw64_win64/9/changes>
> I took a look at the buidl logs for this:
> The error is:
> ../../include/geos/platform.h:71:5: warning: #warning "Could not find 64bit integer definition!"
> But the configure step does find a `long long int` being 64bits:
> checking whether int64_t is 64 bits... no
> checking whether long int is 64 bits... no
> checking whether long long int is 64 bits... yes
> Now this is unexpected because the "Could not find 64bit integer definition"
> should only happen when HAVE_LONG_LONG_INT_64 is _not_ defined:
> #ifdef HAVE_INT64_T_64
> typedef int64_t int64;
> #else
> # ifdef HAVE_LONG_LONG_INT_64
> typedef long long int int64;
> # else
> typedef long int int64;
> # ifndef HAVE_LONG_INT_64
> # define INT64_IS_REALLY32 1
> # warning "Could not find 64bit integer definition!"
> # endif
> # endif
> #endif
> How can I look at the platform.h generated by ./configure on winnie ?
> This is how it looks on my machine:
> /* Set to 1 if you have `int64_t' type */
> /* #undef HAVE_INT64_T_64 */
> /* Set to 1 if `long int' is 64 bits */
> #define HAVE_LONG_INT_64 1
> /* Set to 1 if `long long int' is 64 bits */
> /* #undef HAVE_LONG_LONG_INT_64 */
> I'd expect HAVE_LONG_LONG_INT_64 to be defined there instead...
> --strk;
http://www.cartodb.com - Map, analyze and build applications with your data
~~ http://strk.keybit.net
