[postgis-devel] [PostGIS] #2099: GEOSOffsetCurve: IllegalArgumentException: RobustDeterminant encountered non-finite numbers
trac at osgeo.org
Thu Dec 6 05:11:32 PST 2012
non-finite numbers
Reporter: mamay | Owner: strk
Type: defect | Status: assigned
Priority: high | Milestone: PostGIS GEOS
Component: postgis | Version: 2.0.x
Keywords: ST_OffsetCurve, history |
Comment(by mamay):
Hello guys,
Update on this issue:
after previous fix I have recompiled postgis to POSTGIS="2.0.2SVN r10191"
GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March 2012" GDAL="GDAL 1.9.1,
released 2012/05/15" LIBXML="2.7.2" LIBJSON="UNKNOWN" RASTER
But when executing following query:
select ST_OffsetCurve('LINESTRING(149.536935 -26.1994070007468,149.536737
-26.19960093,149.536935 -26.1994070007468,149.536737
-26.1996010007468,149.536935 -26.1994070007468,149.536935
-26.1994070007468,149.536935 -26.1994070007468)', 3, 'quad_segs=4
join=mitre mitre_limit=2.0')
linux postgresql completely hangs, only restart helped.
windows postgres service shutdown with message: ********** Error
no connection to the server
Connection reset.
Though on windows -------
POSTGIS="2.0.1 r9979" GEOS="3.3.5-CAPI-1.7.5" PROJ="Rel. 4.8.0, 6 March
2012" G
DAL="GDAL 1.9.1, released 2012/05/15" LIBXML="2.7.8" LIBJSON="UNKNOWN"
TOPOLOGY
RASTER
Thank you,
Alex.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/2099#comment:9>
