[postgis-devel] Error building extensions
Jose Carlos Martinez jomarlla at cgf.upv.es
Wed Feb 1 09:31:53 PST 2012
On 01/02/2012 18:20, Greg Troxel wrote:
> This is probably not your problem, but [[ is non specified by posix and
> thus non-portable.
>       while [[ $v -le  ]]; do \
> It looks like the second comparison arg is underquoted; try adding ""
> around it.
Greg, it worked with but Im still getting the first two comments (expr:
non-integer argument) that make me worried:
linux-8hd6:/mnt/tmp/postgis-2.0.0alpha3SVN/extensions/postgis # make
install
expr: non-integer argument
if test "3SVNx" != "x"; then \
    v=; \
    while [[ $v -ge 1 ]]; do \
        cp -v sql_bits/postgis_upgrade_minor.sql
sql/postgis--2.0.0alphaSVN$v--2.0.0alpha3SVN.sql; \
        v=$(($v-1)); \
      done; \
else \
   if test 0SVN -gt 0; then \
    v=0; \
    while [[ $v -le "" ]]; do \
sql/postgis--2.0.$v--2.0.0alpha3SVN.sql; \
        v=$(($v+1)); \
     done; \
   fi; \
  fi
/bin/mkdir -p '/usr/share/postgresql/extension'
/bin/sh /usr/lib/postgresql/pgxs/src/makefiles/../../config/install-sh
-c -m 644 ./postgis.control '/usr/share/postgresql/extension/'
-c -m 644 ./sql/postgis--2.0.0alpha3SVN.sql
./sql/postgis--2.0.0alpha3SVN.sql  '/usr/share/postgresql/extension/'
URL: <http://lists.osgeo.org/pipermail/postgis-devel/attachments/20120201/4c7c9c08/attachment.html>
