[postgis-devel] [PostGIS] #1527: extensions/postgis/topology/Makefile.in uses non-POSIX [[ in makefile
trac at osgeo.org
Wed Feb 1 16:23:58 PST 2012
Reporter: gdt | Owner: pramsey
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: postgis | Version: trunk
Keywords: |
The [[ construct is beyond POSIX specifications, and not all shells
implement it. Even if so, there is no standard for the behavior.
The following diff helps, but because there are underlying issues with
revisions not being numeric, it doesn't work (but I think it fixes the [[
issue).
Index: Makefile.in
--- Makefile.in (revision 9010)
+++ Makefile.in (working copy)
@@ -72,14 +72,14 @@
sql_minor_upgrade: ../postgis_extension_helper.sql
sql_bits/remove_from_extension.sql.in sql/topology_upgrade_minor.sql
sql_bits/topology_comments.sql ../postgis_extension_helper_uninstall.sql
if test "$(PREREL_NUMBER)x" != "x"; then \
v=$(PREREL_PREV); \
- while [[ $$v -ge 1 ]]; do \
+ while [ "$$v" -ge 1 ]; do \
cat $< >
sql/$(EXTENSION)--$(MINORVERSION).$(PREREL_PREFIX)$$v--$(EXTVERSION).sql;
v=$$(($$v-1)); \
done; \
else \
if test $(MICRO_NUMBER) -gt 0; then \
v=0; \
- while [[ $$v -le $(MICRO_PREV) ]]; do \
+ while [ "$$v" -le "$(MICRO_PREV)" ]; do \
cat $< >
v=$$(($$v+1)); \
done; \
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1527>
