[postgis-devel] ST_PixelAsPolygon : what is band number for ?
Bborie Park dustymugs at gmail.com
Thu Feb 2 07:17:27 PST 2012
Yes.  I saw that.  Fixed that r8999.
As for the extension issue, I thought that was because of out-of-sync
docs due to the deletion of ST_PixelAsPolygon(raster, inti , int,
int).
-bborie
On Thu, Feb 2, 2012 at 7:13 AM, Pierre Racine
<Pierre.Racine at sbf.ulaval.ca> wrote:
> Bborie,
> I guess you forgot to remove the band parameter where it is used in ST_PixelAsPolygonS().
> This is causing create extension to fail. See:
> http://postgis.refractions.net/pipermail/postgis-devel/2012-February/018104.html
> Pierre
>> -----Original Message-----
>> From: postgis-devel-bounces at postgis.refractions.net [mailto:postgis-devel-
>> bounces at postgis.refractions.net] On Behalf Of Bborie Park
>> Sent: Wednesday, February 01, 2012 9:33 AM
>> To: PostGIS Development Discussion
>> Subject: Re: [postgis-devel] ST_PixelAsPolygon : what is band number for ?
>> On Wed, Feb 1, 2012 at 6:30 AM, Bborie Park <dustymugs at gmail.com> wrote:
>> > On Wed, Feb 1, 2012 at 12:15 AM, Sandro Santilli <strk at keybit.net> wrote:
>> >> What's the use for band number in ST_PixelAsPolygon?
>> >> It simply returns a polygon convering the area of a given pixel, not
>> >> containing any value...
>> > Nothing.  The function has a comment indicating that it is deprecated.
>> >  Might as well delete.
>> Done in r8997.
>> postgis-devel mailing list
>> postgis-devel at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-devel
