[postgis-devel] [PostGIS] #1532: Have regress install the comments and throw an error if failure
trac at osgeo.org
Thu Feb 2 11:13:32 PST 2012
Reporter: robe | Owner: strk
Type: enhancement | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: build/upgrade/install | Version: trunk
Keywords: |
I think if make check detects xsltproc, it should build and install the
documentation comments.
The benefit of this check is that it catches bugs where we accidentally
remove a function that we have documented or
we change the signature of a function we have documented without updating
the documentation.
Also right now, since the postgis and postgis_topology extensions package
in the postgresql help, they will fail installation if the documentation
and the function signatures do not agree. I think its a good thing as it
insures our documentation is always consistent with what we have coded.
Ticket URL: <https://trac.osgeo.org/postgis/ticket/1532>
