[postgis-devel] [PostGIS] #1499: topology regression tests fail creating already-present schema
PostGIS trac at osgeo.org
Thu Feb 2 19:30:58 PST 2012
 Reporter:  gdt       |       Owner:  strk
     Type:  defect    |      Status:  new
 Priority:  medium    |   Milestone:  PostGIS 2.0.0
Component:  topology  |     Version:  trunk
 Keywords:            |
Comment(by gdt):
 The issue is the same as ticket:1533.
 Index: topology/Makefile.in
 --- topology/Makefile.in        (revision 9013)
 +++ topology/Makefile.in        (working copy)
 @@ -76,8 +76,8 @@
  #Generate upgrade script by stripping things that can't be reinstalled
  #e.g. don't bother with tables, types, triggers, and domains
  topology_upgrade.sql:  topology.sql
 -        sed -e '/^\(CREATE\|ALTER\)
 \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\).*;/d' \
 -                -e '/^\(CREATE\|ALTER\)
 \(CAST\|TYPE\|TABLE\|SCHEMA\|DOMAIN\|TRIGGER\)/,/\;/d' \
 +        sed -E -e '/^(CREATE|ALTER)
 (CAST|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER).*;/d' \
 +                -e '/^(CREATE|ALTER)
 (CAST|TYPE|TABLE|SCHEMA|DOMAIN|TRIGGER)/,/;/d' \
  topology_upgrade_20_minor.sql:  topology_drop_before.sql
 topology_upgrade.sql topology_drop_after.sql
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1499#comment:3>
