[postgis-devel] [PostGIS] #1536: [raster] There should be an option for certain variants of ST_Intersection(raster, raster)
PostGIS trac at osgeo.org
Fri Feb 3 11:18:55 PST 2012
 Reporter:  pracine  |       Owner:  pracine
     Type:  defect   |      Status:  new
 Priority:  low      |   Milestone:  PostGIS 2.0.0
Component:  raster   |     Version:  trunk
 Keywords:           |
Comment(by pracine):
 So I see just two options to solve this:
 1) We add a nodata value parameter and this nodata value is used just if
 the requested band do not have a nodata value defined (if it does the
 passed nodata value is ignored). If this option is chosen I would also
 expect to be able to give an extent to the raster/raster variants.
 2) We remove the possibility to get an other extent then the
 'INTERSECTION'.
 That said I like the fact that we have (in some cases) the possibility to
 get an extent other  than 'INTERSECTION' taking for granted that only the
 intersection is always filled with data...
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1536#comment:1>
