[postgis-devel] [PostGIS] #1536: [raster] There should be an option for certain variants of ST_Intersection(raster, raster)
trac at osgeo.org
Fri Feb 3 11:48:44 PST 2012
Reporter: pracine | Owner: pracine
Type: defect | Status: new
Priority: low | Milestone: PostGIS 2.0.0
Component: raster | Version: trunk
Keywords: |
Comment(by dustymugs):
I wouldn't mind getting rid of the "extenttype" parameter from the
ST_Intersection(raster, geometry) variants. Like you said,
ST_Intersections should ONLY be returning the intersection.
As for being able to specify a NODATA, you should either use
ST_SetBandNoDataValue before calling ST_Intersection or use 2-raster
ST_MapAlgebra.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1536#comment:4>
