[postgis-devel] [PostGIS] #1543: ST_GetFaceGeometry exception on partial face boundary, null on unexistent face
trac at osgeo.org
Mon Feb 6 03:12:57 PST 2012
face
Reporter: strk | Owner: strk
Type: defect | Status: new
Priority: medium | Milestone: PostGIS 2.0.0
Component: topology | Version: trunk
Keywords: |
The SQL/MM document says that an exception should be raised IF the face
argument references an unknown face. Doesn't say anything about faces
bound by no ring (would be due to invalid topology).
The current implementation results in an exception in the latter case (no
ring) but not in the former (unknown face).
In turn this doesn't help validating a topology in that the exception on
invalid topology makes the whole validateTopology function bail out.
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1543>
