[postgis-devel] [PostGIS] #1541: Stop relying on private projects.h PROJ header
PostGIS trac at osgeo.org
Mon Feb 6 09:01:38 PST 2012
 Reporter:  strk                   |       Owner:  strk
     Type:  defect                 |      Status:  new
 Priority:  high                   |   Milestone:  PostGIS 2.0.0
Component:  build/upgrade/install  |     Version:  trunk
 Keywords:                         |
Comment(by pramsey):
 I talked to Frank about this yesterday, and he had no solutions.
 See http://trac.osgeo.org/proj/ticket/142
 Turns out even the API routine that is supposed to access the internal
 information doesn't give us the spheroid parameters.
 For our purposes, can we retain projects.h for proj <= 4.7 and switch to
 using only proj_api.h for proj 4.8+?
Ticket URL: <http://trac.osgeo.org/postgis/ticket/1541#comment:5>
